Heat exchanger
Im presently setting up 21' (tailored) ski boat running 502 BBC, intercooler, twin turbo
Have acquired 7.4 mercruiser heat exchanger, need to plumb up in boat, haven't a lot of room as you guys with 32' plus boats Need some recommendations on: 1. water pickup (1 or 2) either through hull clam shell, or transom (have no holes in boat at present), what size was thinking 1.25" dia 2. using a seacock, shut off valve 3. whether should be using sea strainer, Forspar (looks to be plastic), or a stainless steel strainer (eg Gil, Hardin) 4. do you run separate sea strainer for the intercooler, therefore need 2 external pickups 5. Plumbing guide if anyone has some pictures of setup what be fantastic cheers Brett |
| All times are GMT -5. The time now is 10:54 AM. |
