Originally Posted by getrdunn
(Post 4598641)
I wouldn't advise installing two on a single hatch. That could turn into a nightmare.
Can you expand on this? |
Originally Posted by Boatally Insane
(Post 4598655)
I had to move my hatch ram further to one side to clear my new engine so I put a gas strut on the opposite side to help out a bit.. Works pretty good..
The strut would keep it from wobbling, but it would have to be a pretty low pressure Id think to not make it harder to close, etc. have dimensions/part number for what you used? |
Originally Posted by GrannySShifting
(Post 4598744)
i remember I had a boat with just your basic car hatch strut that worked fine but would just need to work the opposite like a screen door air ram. (Just refeering to the concept not actual) |
(Post 4598820)
Didnt necessarily mean nightmare but more so the possibilities of the rams not going up and down the same.assuming you'd wire both rams to one switch. in a perfect world they would work perfectly without one operating a bit slower in due time and or having intermittent problems with one or the other. Even thought you can pull a pin I would just think they would be in the way and a head banger while wrenching. Not sure sure where your outer stringers are at but will they align ok with hatch without interference. If you did install two I'd glass in a 1 1/2" x 3" board or similar just to help strength and might help even out weight, hatch, etc. Is your hatch fully padded with the seat back attached? I'm just trying to think if there is a way to prevent your problem without having to go through the time and expense. I'm not familiar with the underside of hatch and what it gets pulled down to or not to. Not any other option to eliminate problem. Nice looking boat though....
i remember I had a boat with just your basic car hatch strut that worked fine but would just need to work the opposite like a screen door air ram. (Just refeering to the concept not actual) I was thinking hydraulic, whereas they were connect they would self level like lift.. but that aint this LOL. I can see what you mean. The lift is on a middle stringer dead center, and the outboard ones are in good location to put lifts on either side. Really no way to have offset one of any kind, you have outside edges and center as only real mounting options. Its just the sunpad, no seats attached when raised. The current setup has a steel hinge bar at the back of the hatch (hatch is basically flat square with sunpad on it) two hinge points under swim platform, and two mounting points on underside of hatch 3 screws on each mount point. The fiberglass is cracked up real bad there, cant get screws out stripped etc, so Ive taken it off to refiberglass all that. Was thinking of putting a stainless 6" by 5 ft or whatever plate across it when fixed, so the mount points are distributed across the surface in more than 2 2' circles (pretty dumb design) Honestly with a fresh lift, sturdy base mount it may be perfectly fine no more weeble wobbles? I like the idea of a low pressure gas strut, maybe just add two very light ones on the outer edges for stability with the hatch open and pull pins to drop them out of the way when servicing. |
(Post 4598745)
I like the idea, have any pictures of how offset it is?
The strut would keep it from wobbling, but it would have to be a pretty low pressure Id think to not make it harder to close, etc. have dimensions/part number for what you used? Found the part numbers I used... Hardware ML3000 Gas strut A95767 My hatch ram doesn't pull down, it's set up so I could lift the hatch by hand if the battery is dead. When I close it, I have to push down on the side with the gas strut to get it to close the last 2" on that side but no big deal. https://i.imgur.com/ddBRNzP.jpg https://i.imgur.com/yGTStTF.jpg |
Of course the pitures dont show haha
Hey I might have to eat my words and is what it is but ck out swap right now. How coincidental!!! Slick set up FS.
(Post 4599062)
(Post 4599103)
https://www.offshoreonly.com/forums/...tch-lifts.html |
(Post 4599062)
There is a YouTube of those Dana Hatch lifts in action I saw a couple years back. Not sure what pump the guy used but they opened in like 4 seconds and closed in 2-3 seconds. :eekdrop: |
| All times are GMT -5. The time now is 10:20 PM. |
