700 sci valve springs
Ok guys i know this topic has been covered more then once my question is what springs can I switch to from stock that will perform a little better my boat has the stage 3 whipples so im pulling a little higher then stock rpm 6k vs 5400 that being said I re propped the boat so the highest it will pull now is 5700 ish I know the stock springs were light on the seat I'm also replacing the crane gold rockers with the scorpion marine endurance and I will also be switching to 10 degree locks and retainers any help is greatly appreciated thanks.
Probably Isky 8005sp or 8005plus, but I would check with Eddie Young and see what he recommends
Originally Posted by Griff
(Post 4619838)
Originally Posted by Nate_106
(Post 4619965)
Do you happen to know what locks and retainers to use?
One more VERY important note. When you change the rockers, be sure to reuse the existing rocker stud nuts / polylocks. Do NOT use the ones that come with the Scorpion rockers. The OEM nuts are shorter than what typically comes with new rocker sets and the valve covers will not clear if you don't reuse the OEM nuts.
I just did 10* in my build. Did all Isky.
8005A -springs 200-ST-10DEG -Retainers VL-10-3-8 -Locks |
Get ahold of Eddie Young I got all my goodie,s , rocker,s spring,s retainer,s from him a decent price top shelf stuff .
Thanks guys it’s greatly appreciated |
| All times are GMT -5. The time now is 09:53 PM. |
