Might try a water pump bypass hose from a chevy truck or look at Stainless Marine hose it is a fairly tight 90 deg bend.
My O'Rileys lets me hose shop in the back isles as long as it takes. Looks a lot better but you need to resolve those short hoses. |
Originally Posted by GLENAMY 242SS
(Post 4630765)
Much better. Looks 1000x better!!!! Nice work. Enjoy!!! |
Thats exactly what you needed!
it looks like you could cut some hose length off the bottom side should make it better
In terms of the rubber hose...instead of using a straight fitting on the riser/tail, maybe use a 45* fitting. |
The connection you are trying to manufacture out of straight hose is supposed to be a molded hose. The straight hose will eventually get warm and kink. When it kinks you lose water flow and will burn up the exhaust. |
EMI shows the U shaped connector hose in their installation guide. Looks like the fitting on the manifold may be a 45 with riser being straight. https://www.eddiemarine.com/image/da...ions%20PDF.pdf |
Originally Posted by OPIE272
(Post 4631351)
The connection you are trying to manufacture out of straight hose is supposed to be a molded hose. The straight hose will eventually get warm and kink. When it kinks you lose water flow and will burn up the exhaust. And those intstructions you a referring to are for a different riser than what I am now using. |
Originally Posted by jryotas
(Post 4631403)
I am actually trying to use the u shaped hose from emi . They are going to try and send me a 45 to use on the riser but I am thinking that then I will only have 1" space between the riser nipple and the manifold nipple . May present a different issue. We will see .
And those intstructions you a referring to are for a different riser than what I am now using. Be happy with fit and function on the hose and fittings that you are working on. It is critical to not restrict the flow. |
| All times are GMT -5. The time now is 09:51 PM. |
