overheated 92 454 (330hp) - now slow to turn over and no compression on many cylinder
#41
I think your path forward depends on 2-3 things...
1. Tinkering with a used motor vs. buying a new drop in motor and go
2. Performance
3. Cost
which ones matter to you...?
2. Performance
3. Cost
#44
coolrunning racing
One (of many) explanation for the valve issue is detonation. It super heats the combustion temperature and the does what is called "tulip". The valve head starts to cup like a tulip, now it is longer and hit the piston. Game over. This can be caused by over propping, poor fuel (old,cheap ect.), water intrusion or lack of proper maintenance.
#45
The peanut motor will work. The 330 merc IS a peanut motor. Your stuff all came orig on peanut heads. Your raw water pump. Does it look like this? With a mech fuel pump on it? https://m.ebay.com/itm/RAW-SEA-WATER...ox!08093!US!-1 it will be sticking straight up. If so, you have no fuel pump issue and yours is the same engine. Different cam, but not that different.
#46
Should I be concerned that he said the compression is only 105 per cyclinder - his excuse is that the engine has been sitting for 2 years and the cylinders/pistons are dry and thus the rings aren't seated great - he said once it gets running and oil circulates that the rings will seat better and I should get 130+ on each - does this make sense?
#49
I was running with my 19P, at when it overheated was doing 4000rpm without pulling anyone - just had my son and i in the boat. The 19P was good for me as I could get it to 4500 if WOT.
Still not sure why the valve stem broke - where it broke is has a 1" black mark throughout - does this imply it burnt? Or could it just be wear and tear and these valves and stems were old, being I bought the heads used with these valves and stems on them and I didn't replace them when I put the heads on my boat last year?
#50
Thanks for the confirmation - I sent him an offer of $400 but will likely buy it even if he wants more - I spoke with him quickly yesterday and he said he would do $500 - even if I pay $500 sounds like a good deal for an assembled 454 up to the heads. Thanks
