-   -   Volvo Penta DPX 600 service manual (https://www.offshoreonly.com/forums/do-yourself-boating-budget/355373-volvo-penta-dpx-600-service-manual.html)
TorB 07-16-2018 11:44 AM
Is there anybody that have a pdf version of the DPX 600 service manual for a 2001 engine. The electrical drawings and the documentation for the ignition and the fuel system is the most important.
I am living in Norway and cant find the manual here in Norway. The volvo dealer do not have it.
Any information will be appreciated.
I have a copy of the part list catalog for the DPX 600.
BUP 07-16-2018 11:14 PM
there is none for the engine side - I have files of sections for the engine side only. The outdrive has a manual. I would have to see about extra manuals for the outdrive.
TorB 07-17-2018 12:42 AM
Does it exist any documentation for the wiring, fuel system and the electronics for this engine? (The ECU and cabling)
Or do you know if Volvo did use the same wiring diagram and ECU as for the 8.1 litre engine (reprogrammed for the DPX 500 and DPX 600 engine)?
scarabman 07-17-2018 09:22 AM
Call Innovation Marine, who built the engines, and they will be able to help you out. Scott Yow is who I spoke with most times. Not sure if Dave Stiff is still there, but he had in depth knowledge of the 600s and DPX drives. Every time I ever had a question regarding my 600 DPXs, they always helped out. If for whatever reason you may need another ECU, I have one with factory/Innovation 600 tune
TorB 07-23-2018 07:01 AM
BUP Is it possible for you to share your files? :pray:
