Mabey I知 learning,,
Old 07-24-2018 | 07:27 PM
  #31
Ok, just reread, you do recommend 3D timing, using a 2bar sensor. As I said in the beginning of this thread, all this is new to me. And if I need 1200$ worth of ingition, so be it. I知 sure the Wife will understand.(Mabey)
Scscoripion is offline
Old 07-24-2018 | 07:39 PM
  #32
You certainly dont "need" a 3d timing table with map sensor. However, for the extra 75 bucks or whatever the map sensor kit goes for, i think its worth it. Once you learn how to use the software, its nice to be able to datalog the runs and monitor map at various rpms.
believe me, i am no computer genius thats for sure. It took me a while to figure out how to work with the software so i totally get it!
MILD THUNDER is offline
Old 07-24-2018 | 07:45 PM
  #33
Scscorpion. Just remember most blower motors that blow up are from improper tuning. People will blame all sorts of stuff and there are certainly other factors but tuning is usually the number 1 cause.
Crude Intentions is offline
Old 07-24-2018 | 08:06 PM
  #34
MR Thunder , Mr Crude , I hope you Gus understand how much your input/ advice means to me! Where else could I turn with these type of questions? So, you recommend Daytona ingition systems, with map sensors, -2bar. That痴 what I知 doing. As far as mapping, all that other stuff, my son may be able to do that. Looks like a double this Sunday! LOL
Old 07-24-2018 | 08:12 PM
  #35
Will the AFR痴 be able to help, from my understanding that痴 critical, my carb guy recommended 12.8. - 13 , is that kinda lean? From what I can remember,11.5-12 was good for these carbed motors? Never had an AFR gauge befor , (innovate gauges)
Old 07-24-2018 | 08:18 PM
  #36
Also , carb guy said my carbs are about 1000cfm after his mod痴 , that wasn稚 cheep at all! Ever heard of APD in Genoa Ohio?
Old 07-24-2018 | 08:21 PM
  #37
( Advanced product design)
Old 07-24-2018 | 08:23 PM
  #38
The afrs will give you jetting/timing advice. It’s defienitly a trial and error process. One thing we all learn is these ****ers are anything but cheap but get a lot more expensive if you cheap out. Read a lot on it. 13s I think your starting to get lean. I would guess mid 11s to mid 12s would be safe ranges. Others will chime in and give more specifics there.
Old 07-24-2018 | 08:57 PM
  #39
Thanks Crude, I thought 12.8- 13 would be lean, I have the jet and pv spects, will post them as soon ,
Old 07-24-2018 | 09:06 PM
  #40
Jet front-.096 , rear -.106. Pvfront4.5. Squirter .035. Pv rear -na. Idle.063 front .063 rear.
