Distributor gear for Comp Cams billet stick? >
Like Tree2Likes
  • 1 Post By Baja Rooster
  • 1 Post By BillK
Old 09-13-2018, 03:51 PM
Default Distributor gear for Comp Cams billet stick?
Brand new Comp Cams billet hydraulic roller cam 525EFI clone with DUI distributor. Iím trying to figure out what gear I currently have, or I guess the best option is the composite unit?
Baja Rooster is offline
Old 09-13-2018, 03:53 PM
SB
What is the part# of the cam ?
SB is offline
Old 09-13-2018, 04:05 PM
Part# 01-446-8w
It says that itís a pressed on cast gear on the cam.
SB likes this.
Old 09-13-2018, 08:05 PM
Originally Posted by Baja Rooster View Post
Part# 01-446-8w
If that is the case then a stock gear will work fine. I prefer to replace them when going with a new camshaft.
SB likes this.
BillK is offline
Old 09-13-2018, 08:16 PM
A hardened steel gear, correct?
Old 09-13-2018, 08:47 PM
SB
Part# 01-446-8w
Thanks, that's why I asked. Stock cast iron gear will suffice. Cam has same gear a flat tappet cam could have.
SB is offline
Old 09-13-2018, 10:04 PM
Thanks all. The one question I had was does this look like a cast gear or steel?
OSO Sponsor
OSO Advertiser
OSO Advertiser
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
OSO Advertiser
