Cooling - Hull water pickup >
Old 12-07-2018, 08:44 PM
  #51
Dan
so at sea strainer the pressure will be greater depending on speed and if there is blockage ?
do you know what pressure the relief valve is set to bleeding off at strainer ?
I was thinking of putting pressure relief valve either
1. T in-line from strainer to pump
2. In line between pump and first heat exchanger (engine oil)
anyone has opinion??
brett fiddes is offline
Old 12-09-2018, 07:16 PM
  #52
Charter Member #394
SFOcean's Avatar
Originally Posted by brett fiddes
Dan
so at sea strainer the pressure will be greater depending on speed and if there is blockage ? Yes on speed, usually lower past strainer if blockage is in strainer
do you know what pressure the relief valve is set to bleeding off at strainer ? 30 to 35lbs
1. T in-line from strainer to pump YES, as Dan stated above
See answers above in blue.
SFOcean is offline
Old 12-12-2018, 05:21 AM
  #53
Water pick up update:
have relocated the water pickup hose coming into side of sea strainer now upgraded to 1.25" hose
managed to move sea strainer down 3" and back 2"
plumbed 1.25" fittings to route water out of bottom of sea strainer, and T off one of the fitting by welded 1/2" NPT fitting into line, will put the 1/2" adjustable relief valve in here and route to outside of boat above water line
Plumbed up P/S and Engine HX
Just need to mount the Jabsco crank and route the 1" hoses either side of the sea pump to sea strainer and into bottom HX
Then need to think about where to mount the mercruiser closed water HX and connect up the hose from top HX
P/S and Engine HX
Sea strainer plumbed in
Old 12-12-2018, 12:02 PM
  #54
Team Archer's Avatar
That Jabsco pump should have 1.25 hose barbs on it you should feed the engine with the 1.25 hose also. Regards Dan
Team Archer is online now
Old 12-12-2018, 01:53 PM
  #55
Dan
yes sorry
hose coming from strainer is 1.5" and then steps down to 1.25" in/out of pump
