-   -   "575 GM 540" Build 1988-1992 (https://www.offshoreonly.com/forums/do-yourself-boating-budget/358532-575-gm-540-build-1988-1992-a.html)
automobili_v12 01-11-2019 09:12 AM
Hi, Im trying to build a 1988-1992 "575 GM 540"
I think its a 502 Block Non Roller and 4.25 Crank and 088 Heads.
Would it be better to use a 502 Roller Block?
1- What Pistons and Rods?
2- Camshaft?
Camalot 01-11-2019 02:45 PM
The only real gain going with a gen 6 would be the one piece rear main seal, but I've never had a problem with the two piece!! the lifter bores are higher but again don't see many problems with the older blocks.
I would defo go with the later step nose cam and use the gen 6 cam retainer Comp Cam 01-446-11 would be a good cam.
flashgordon 01-14-2019 07:13 AM
540 s
not sure what you are trying to build a 540 cu in motor??
a 540 is 4.25 stroke and 4.5 bore
i run isky red ball series solid roller lifters, 700 lift 285/295 duration
my motors a mark4
srp piston 10.3 to 1
eagle rods
never had issues with two parts rear main seal.
