-   -   Rebuilding stringers, floor, and transom (https://www.offshoreonly.com/forums/do-yourself-boating-budget/358659-rebuilding-stringers-floor-transom.html)
LostinBoston 01-20-2019 11:18 AM
I’m considering a project boat. It will at least need new stringers and floor, possibly transom. Who has done this before and has some words of wisdom. What is a realistic cost and level of effort for a 23’ boat? I’m thinking Coosa for the transom, posssivle floor, and seacast or Nida for stringers. Any other materials to look at? Thanks for your suggestions.
Griff 01-20-2019 12:30 PM
Lots of threads in the Fiberglass and Paint Section. That's a whole lotta work for a 23' boat.
getrdunn 01-20-2019 07:06 PM
Unless I had a diamond in the rough priceless boat I'd find another project boat. Trust me....
phragle 01-20-2019 08:49 PM
You do not want to do a coosa transom.
LostinBoston 01-21-2019 11:27 AM
What material would you recommend and why?
Knot 4 Me 01-21-2019 11:54 AM
Plywood.
ren3 01-21-2019 02:07 PM
Find a 23' boat that doesn't need so much work. It will be cheaper than your project in the long run. I did my 28' hull for two reasons. It is a Cigarette Racing Team hull, and I am crazy!
Crude Intentions 01-21-2019 02:14 PM
why? Seems that’s what most builders use now
phragle 01-21-2019 06:16 PM
3 layers of 1/2" marine ply laminated together. Coosa is great stuff when used in conjunction with its properties. As a stringer or bulkhead its great (with the exception of the motor mount area on the stringers)
For a transom, it does not like compression and shear.
flashgordon 01-22-2019 11:32 AM
wow,,,i did not do the glass work , but gutted my engine compartment of everything
u will have to reset your motor mounts
need alignment tool for that
lots of work...
i post a thread
38 scarab rebuild
oconnor marine 01-22-2019 12:01 PM
Dont do it
flashgordon 01-22-2019 12:03 PM
[QUOTE=flashgordon;4669217]wow,,,i did not do the glass work , but gutted my engine compartment of everything
lots of work...
i posted a thread
replacing main stringer and transom
kel954 01-26-2019 03:37 PM
I patched a huge section of my floor with no prior experience with fiberglass. Had a lot of people telling me i was in over my head but i did it anyways and it turned out great. theres plenty of youtube videos that gave me great advice and techniques. Coosa board is pretty easy to work with.
