-   -   Main/Rod Bearing Clearances (https://www.offshoreonly.com/forums/do-yourself-boating-budget/359529-main-rod-bearing-clearances.html)
automobili_v12 03-12-2019 09:39 AM
Hi, Im building a 454 Stroker, what Main & Rod Bearing Clearances would be recommended.
beaver 3 03-12-2019 11:15 AM
I built mine to .0025 - .003. I run 20/50 oil oil pressure is always good. Only about a season and a half on the motor now though probably around 20 hours.
getrdunn 03-12-2019 12:22 PM
Going off memory and not manual but .0027-.003 on rods and .003-0035 on mains. Some shops run slightly more clearance or the rear main. Closed or open cooling? I've always went by marine engine speed shop and seems like we always ran on the higher side due to the cooler water and oil temps. BUP should be able to get you spot on if he chimes in.
flashgordon 03-17-2019 11:06 AM
i have 0028 on rods and 0035 on the mains
automobili_v12 04-18-2019 07:40 PM
Can anyone else chime in,
Thx
sutphen 30 04-18-2019 09:13 PM
Thx
why,,how tight are yours?
Rookie 04-18-2019 09:31 PM
Thx
Those are the proper tolerances. What more are you looking for? I run on the higher end. Cooler engines (120°F) and oil 165°F, 15/50 Mobil 1 oil.
automobili_v12 04-19-2019 09:21 AM
Should I run the bearings -.001 extra on the clearances for more Lubrication?
ph1971 04-19-2019 10:34 AM
.0028 main and .0025 rods in my 540
Rookie 04-19-2019 10:20 PM
No, you should run within the tolerances given. Lubrication is a little portion of oil. More importantly it works as a hydraulic stabilizer when the charge is set off in the combustion chamber. The oil is a non-compressible fluid and creates a cushion between the journals and crank so they don't slam into one another. Tolerances are critical and no need for you to try to engineer new tolerances. Between the given tolerances is personal preference and build design specific.
