Trouble shooting Bravo 3 outdrive trim gauge
Does anyone have a flow chart to trouble shoot the trim gauge/sending unit.
Trim works wonderful but the gauge isn't registering- not sure if it is a wire from the sending unit or something internal to the gauge.
Any help would be appreciated
Thanks in advance
3pointstar
Thanks in advance
3pointstar
Sending units can rust/corrode up over time and fail. That's more than likely the culprit. Check to make sure both wire connections are good first. Also I've see the gimble bolt loosen and pivot with the sender. Confirm both sides are tight.
Does it read the same with drive up?
If yes and
Assuming you don’t have smartcraft.
Find the 2 wires that come from the trim sender thru the gimbal housing and are tie strapped to the back of the engine. Disconnect them and put a short piece of wire between the 2 wires on the engine. Key on and look at gauge. If it now reads full down, you need a new sender. If it’s still up, post back and we can work thru gauge / wiring troubleshooting.
If yes and
The position adjustment is the puck on the starboard side. Odds are it’s time for new ones. The internals get corroded and fail. There are a few places where you can buy replacement internals if you want to try that. The actually sending unit can be bought new for roughly $70. It’s the R&R that makes it a chore because the drive needs to come off
thank you - I located the wires today before I had a chance to read your message - next time at the boat will give it a try.
Thanks again for you help
3pointstar
3pointstar
The pucks come together in a kit (sender and limit). Sender is probably full of water. While replacing them it would be a good time to replace bellows if they've never been touched. Driveshaft, exhaust (unless Corsa then you would have a tube), shift cable.
