Gen 3 cool fuel - replace wire harness >
Old 04-14-2019 | 02:49 PM
Default Gen 3 cool fuel - replace wire harness
All, this is my first post here.
I have twin 2008 mecruiser 350 MEI Horizon engines. They have Gen 3 cool fuel modules.
I had to take one apart for a low pressure fuel pump replacement, and as part of this noticed the wire going into the housing is broken right AT the housing. So i need to remove the wire harness from the cover, but can't figure out how.
The wires pass through a plastic piece into the housing, but i'm not sure how to get that out, should it be tapped out? I see no retaining clips, threads, etc. I don't want to just start banging, but need to fix or replace the harness.
Anybody know how to get it out properly?
dangel0m is offline
Old 04-14-2019 | 02:54 PM
these are pix of the harness at the housing...
it won't let me post photos since i'm new... sorry
dangel0m is offline
Old 04-14-2019 | 04:18 PM
Have not removed the harness but manual and parts break down show a retainer and set screw under the top cover
https://www.mercruiserparts.com/bam/...31749/11652/70
AllDodge is offline
Old 04-14-2019 | 06:11 PM
All,
My impatience got the better of me. Thanks Alldodge... i had taken off the retainer... so i gave the plastic block a couple taps with a hammer/piston and it moved a millimeter, so i tapped it all the way out. The plastic part has two o-rings to make the seals, but otherwise is simply pushed in.
thanks,
dangel0m is offline
