-   -   Rotten engine stringer ideas for replacement (https://www.offshoreonly.com/forums/do-yourself-boating-budget/360598-rotten-engine-stringer-ideas-replacement.html)
cdowjr 05-13-2019 06:58 AM
cdowjr 05-13-2019 07:01 AM
Help!!
So I cut this out. I can make a new one with 1.5 inch marine plywood or two pieces of 3/4 ply no problem
i can cut bottom at angle needed & epoxy bond to floor then lay glass onto it!
how in heck is this going to then handle 840 hp!!!
Any tips would be appreciated!
Cliff in maine
BLAD 05-13-2019 09:05 AM
scrap your plywood idea and start with solid pieces of wood
cdowjr 05-13-2019 09:24 AM
What wood should I use if you don’t recommend plywood?
StewLow 05-13-2019 10:47 AM
There are many threads on here and a wealth of expertise.
Search and you’ll get all your answers.
I would check all your stringers and transom very carefully. If rot is in one place it’s likely in other areas. I’ve been down this road.
I would cut out the entire stringer and replace with replace with laminated marine plywood.
Again their are others on OSO far more knowledgeable than I.
oconnor marine 05-13-2019 02:37 PM
What year make and model is that boat?
cdowjr 05-13-2019 02:57 PM
1986 checkmate 30 foot
building up 632 ci 850 engines.
id like my engine mounting system to be bulletproof!
has anyone ever glassed in strips of 1/4 stainless with tabs sticking up. Then bolt an aluminum plate to that to mount motor? I’d like to get away from plywood!
phragle 05-13-2019 08:25 PM
Properly built, a good marine plywood with 3 or 4 layers of 1708 is a hell of a lot stronger than you are giving it credit for........
