Fuel Line Tank Return from Regulator
I installed Young's larger tank pickups for the A1000's and am now looking at a way to return the fuel to the tank from the regulators.
I am finding a bunch of diesel sumps that can be installed in a plastic fuel tank. Any options anyone knows of to return two -6 lines to the tank? I'll need to add holes and don't want to run 25' of fuel line to the filler neck. |
If you have an open port on the water separator filter block you can return it there.
(Post 4687002)
No concerns on aeration? What about heat and vapor lock? I know the factory does it, but I eliminated the cool fuel as Eddie said to return it to the tank. |
Brad Smith built my 540's with 500 EFI intakes and thats the way we did it........Whipple recommends doing it the same way on the 3.3 EFI kits.......and no never had an issue in my boats,
Edit: cool fuel is garbage, but you know that |
WE run back to the filler hose with a sleeve so that we don't aerate the tank. WE just run 1 larger line from the engine room and tie the 2 returns together. Regards Dan
(Post 4687026)
Edit: cool fuel is garbage, but you know that I can try it back to the filter head, if it doesn't work I can always run it back to the tank. I don't like the idea of more holes.... |
I believe jegs makes a 1,5” sleeve With a 3/8s nipple that can be spliced into the gas filler hose for return lines |
Originally Posted by 598
(Post 4687251)
Originally Posted by mike tkach
(Post 4687257)
i got mine from teague,really nice polished stainless steel.
https://www.cpperformance.com/c-500-...s-returns.aspx https://cimg8.ibsrv.net/gimg/www.off...1a6956a2b5.jpg
(Post 4687251)
https://www.moroso.com/efi-fuel-return-line-kit65385/
For 2 inch fuel fill line, I have them without the 2 rubber hose splices making the price a tad cheaper and MY SHIPPING IS NOT GOING TO BE 30 bucks either. |
