Holley/ Starting issue
Old 05-18-2019 | 12:50 PM
F-2 Speedy's Avatar
typically the starter solenoid is mounted on a bracket at the rear of the head
F-2 Speedy is offline
Old 05-18-2019 | 01:23 PM
SB
depending on engine it can be mounted in frt, over fuel seperator, or in the rear to the sideof distributor area.
You can also follow the yellow/red from Starter terminal 'S' (smaller terminal just to the right(block side) of the big + terminal.
SB is offline
Old 05-18-2019 | 04:30 PM
Wiring is good Key to signal power out of solinoid
LTZCrew is offline
Old 05-18-2019 | 04:34 PM
F-2 Speedy's Avatar
explain what its doing again, do you think you're losing voltage to the ignition when you stop cranking it ??
Old 05-18-2019 | 07:25 PM
it cranks and wont fire. When you let go of the key -returns to the on/run position. It will stumble a few times as if it where running
Have fuel have spark have air. Was running on dyno not long ago. Nothing on the motor it self has changed. Only new things are fuel system. Cannon plugged into the rest of the boat Ecu is mounted to the boat. And running off boat batteries Confirmed charge is good and had a booster on it well cranking
LTZCrew is offline
Old 05-18-2019 | 09:20 PM
SB
That is what usually causes 'starting to fire' when releasing the key from 'crank.'
SB is offline
Old 05-18-2019 | 09:23 PM
where do I test to see this. ? This would be the yellow/red wire I'm guessing?
I have a starter solinoid relay on order just to be sure. It's a P IA to get at so I think I should replace it to be 100%
LTZCrew is offline
Old 05-19-2019 | 04:52 PM
No one? Everyone out enjoying the water
LTZCrew is offline
Old 05-19-2019 | 07:35 PM
If the motor cranks over the yellow/red wire is fine.
Are you seeing cranking RPMs on the labtop?
Also what is battery voltage on the labtop while you are cranking?
kvogt is offline
Old 05-19-2019 | 07:38 PM
sees rpm Lowest voltage saw was about 10. Had the batteries on a charger and tried using both. Made no difference
LTZCrew is offline
