Blue wing nut for water release on engine >
Old 05-19-2019 | 02:27 PM
Went and picked up some EZ outs. Will give it a try when the wind dies down so I can get my cover off.
iroc fan is offline
Old 05-19-2019 | 02:28 PM
Originally Posted by BUP
or these if you really like
the wing nuts - and no link needed
i like that one, where can I get them?
Alwhite00 is offline
Old 05-19-2019 | 03:28 PM
BUP
no link or site needed since I provided the info and the pic
How many would you like have 50 on hand
BUP is offline
Old 05-20-2019 | 08:54 AM
SABER28's Avatar
when i had them break i used an easy out. replace them with the hardin ones. used them for three years now, never came out hard yet.
SABER28 is offline
Old 05-20-2019 | 09:08 AM
SABER28's Avatar
you can find them with a quick search of google images for brass drain petcock OR you can support your fellow oso member and buy them here.
SABER28 is offline
Old 05-20-2019 | 09:52 AM
how much each?
Old 05-21-2019 | 08:49 AM
I could be wrong but the brass wing plug looks like a tapered pipe thread. How is that going to fit a hole tapped for 1/2-13?
thirdchildhood is offline
Old 05-21-2019 | 08:12 PM
I have a slight problem. I was getting my boat ready for spring and two of the five blue wing nuts that release water from engine broke. One is near the water pump and I can get at no problem, but one below the engine on the cool fuel is hard to get at and I broke the wing part off and its all chewed up from me trying to get it off. They both leak and I need to get them fixed before I take the boat out. How can I get this broken chewed up one off that is below the engine. Its just getting more chewed up the more I try to remove it. Any ideas??
This happened to me one time on a 502MAG. I took a drill bit slightly larger than the hole in plug, pushed it in the plug, and was able to twist out by hand the threaded barrel piece left in place......
imartin is offline
Old 05-21-2019 | 09:07 PM
F-2 Speedy's Avatar
no,,,,, your not wrong.........those are block drains or what ever else has a pipe thread
F-2 Speedy is offline
Old 05-26-2019 | 08:16 PM
Got the leaky broken one out on the cool fuel unit with the EZ out. Replaced all of them with the Hardin Marine ones. Thanks guys!!
iroc fan is offline
