Blue wing nut for water release on engine >
Old 05-27-2019 | 08:19 AM
  #31
Originally Posted by iroc fan
Got the leaky broken one out on the cool fuel unit with the EZ out. Replaced all of them with the Hardin Marine ones. Thanks guys!!
Good! I got my Hardin ones too. 6 of them for $43 shipped.
thirdchildhood is offline
Old 08-13-2020 | 07:24 AM
  #32
SB
Originally Posted by Alwhite00
i like that one, where can I get them?
McMaster Carr for cheap
Same one’s Volvo Penta andcetc use for block drains
https://www.mcmaster.com/4921K2/
SB is offline
Old 09-01-2020 | 01:20 PM
  #33
Last time this happened to me couple boats back on a 502MAG, I used a bigger drill bit than the hollow hole left behind. I guess its the same as an EZ out, but the drill bit method, turning by hand, worked for me....
imartin is offline
Old 09-02-2020 | 10:14 PM
  #34
Do those replace the blue plastic "wing nut" in the plastic elbow?
I have the Hardin Marine SS ones and stripped the threads in the plastic elbow with one. Drained the water on a warm engine (soft plastic) and re-installed it while hanging up-side down over the rear bench seat. So it cross threaded pretty easy. This would be a MUCH better set up IMO.
What I just bought was the brass elbow with the brass nut to remedy this, but see that brass and aluminum have bad corrosion problems. This concerns me greatly as the cost of manifolds is expensive.
I do have the pencil anodes installed in the manifolds which should help, but mot sure how much? .
xlint89 is offline
Old 09-03-2020 | 07:40 AM
  #35
SB
What I showed is two piece. The bottom has npt (national pipe thread) threads. Like what is in the engine block.
SB is offline
