-   -   Blue wing nut for water release on engine (https://www.offshoreonly.com/forums/do-yourself-boating-budget/360712-blue-wing-nut-water-release-engine.html)
iroc fan 05-18-2019 05:23 PM
I have a slight problem. I was getting my boat ready for spring and two of the five blue wing nuts that release water from engine broke. One is near the water pump and I can get at no problem, but one below the engine on the cool fuel is hard to get at and I broke the wing part off and its all chewed up from me trying to get it off. They both leak and I need to get them fixed before I take the boat out. How can I get this broken chewed up one off that is below the engine. Its just getting more chewed up the more I try to remove it. Any ideas??
phragle 05-18-2019 06:04 PM
Those things are known to break when they get old... but the broken part usually comes out really easy. Last time I removed a broken one I just pushed a philips screwdriver in and it twisted right out. You can get a pack of new ones cheap enough, I would replace all of them if a couple are starting to go, cheap insurance,
phragle 05-18-2019 06:11 PM
https://www.offshoreonly.com/forums/...rs-broken.html
F-2 Speedy 05-18-2019 06:26 PM
ez-out
shunter2005 05-18-2019 06:51 PM
As Phragle said, screwdriver is easy way to get broken one out. I used to use a flat blade, but either would work. Go back with Hardin Marine SS plugs. You will not have to worry about them anymore. They actually cost about the same as the OEM blue plastic plugs.
https://www.hardin-marine.com/p-8107...8m2000874.aspx
Alwhite00 05-18-2019 09:24 PM
Heat up a flat blade screwdriver and shove it into the plastic, let it cool and you can then twist it right out.
years ago I bought some stainless ones someone on one of the fourms was selling. They were painted blue and really nice. Lost the contact info so if someone knows......
underpsi68 05-18-2019 09:44 PM
When you get the plastic out here is a good replacement Hardin Marine - Stainless Steel Lifetime Series Sea Pump Drain Plugs - Mercruiser 22-806608A02 / 8M2000874 https://www.hardin-marine.com/p-8107...8m2000874.aspx
SABER28 05-18-2019 09:53 PM
yes, the hardin stainless ones are great.
SB 05-18-2019 09:53 PM
when i reinstall I put oil or spray silicone, or etc onto threads. The o-ring seals them, so don't tighten hard. They are not pipe threads !
I keep several on hand in case one feels tough starting to going in thus meaning threads are damaged. I have broken only 2 in almost 20 years.Last one,about 18 years ago. :)
Over tightening is why they end up breaking. And most of the time it is when trying to remove.
underpsi68 05-18-2019 10:02 PM
Put a little anti seize on if using the stainless plugs.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
