502 Mag Procharger Intercooler Plumbing and Sea Pump
I am running the cooling from the crossover tube to the bottom of the intercooler and going overboard. The oil cooler is heating the water to 130* and I am feeding that to the intercooler. I don't like it.
Is there a two-stage pump that I can run in place of the factory? Moving the intercooler line to before the intercooler would be a PIA!
What are some more options?
Im running two stage pumps -12 to the intercooler....-20 to the engine
No issues with clearance, had to drill a hole in the off shore mount for the input feed from the strainer, you can see it in the pic.
I am with Smitty, my pump is so close to the stringer on the port engine it's not even funny. I have every window open right now from CP Performance looking for a rear feed, bottom output pump.
I could probably make something work on the Starboard. Its the whole hanging upside down thing that I getting effing tired of!
Thank you for the pictures! They help a ton!
the mounting bracket is part of the pump
