First timer with marine headers... >
Old 08-02-2019, 04:21 PM
another question for you guys...someone local responded to my wanted to buy ad for my tailpipes i need. now he has the bravo style tailpipes i need but they are set up for silence choice..im looking to run them temp till i find another set but think i woul dhave any issues blocking off the silence choice option and running them?
chrisbc75 is offline
Old 08-02-2019, 04:54 PM
just run the exhaust hose from the tails to the tips. Just remember, CMIs are NOT a bullet proof option, they do develop leaks.
There are a lot of options between stock and cmi's...
phragle is offline
Old 08-02-2019, 05:23 PM
i already have the manifolds I got them for a dea and pressure tested them. All is good. Now your saying to run a hose from the silence choice cut out into the the tips? Figured I would be okay just blocking them off for now
Old 08-02-2019, 06:02 PM
I thought you didnt have silent choice....Do you have a y pipe, or are you straight out the back??
phragle is offline
Old 08-02-2019, 06:55 PM
im straight out the back thru haul..but the tailpipes I need I found them locally but they have the Aiken choice option. What I was wondering was can I cap the side cutout for the silent choice and use them like thru hauls..
Old 08-02-2019, 07:16 PM
you need tp post a pik..usually the diverter is a separate piece that attaches between the tail and the tip with pieces of exhaust hose.
phragle is offline
Old 08-02-2019, 07:18 PM
Then there is also a significant chance that nothing will line up with the existing holes in the transom, You may get lucky, but its not uncommon to plug the holes and cut new one.
phragle is offline
Old 08-02-2019, 09:23 PM
I can’t post pictures till my post count is up. But that exact picture you posted im asking is the opening going down to the Y pipe( on the exhaust tail) can I plug that since I don’t have silent choice. I would be running it just straight
Old 08-02-2019, 10:34 PM
Donteven put that part on... just use the black exhaust hose to connect the tail to the tip.
phragle is offline
Old 08-03-2019, 12:44 PM
offthefront's Avatar
Question number 1... Do you actually need headers?
What in the Hell is that kind of question? Are you related to my wife? ........ Of course he needs headers ......m
offthefront is offline
