-   -   Spark plug wire question (https://www.offshoreonly.com/forums/do-yourself-boating-budget/362208-spark-plug-wire-question.html)
Prestigeworldwideee 08-03-2019 10:15 AM
Okay guys, don’t murder me over this question.... I wanna replace my old stock 1989 spark plug wires on my 1990 454 mag. I see the part number 3q89 and I saw one wire that said 4q89. I’m having trouble finding them online and I’d rather skip a store where I’ll be charged way more. Any info and or links would be awesome, eBay is usually my go to for parts.
flashgordon 08-03-2019 12:33 PM
hello,
i buy almost everything i can from summit . com !!!!!!!!
their return policy is great ,,,fast delivery,
cant beat them
i do sometimes suf around and buy from other shops...
just my 2 cents
SB 08-03-2019 01:59 PM
The last two#'s stamped on the ignition wires from Mercruiser are the year the wires are made. Nice feature so we know how old they are. If 89 is last two #'s on the wires, yours are original as they where made in 1989. Yup, that old...lol...I removed a set of 88's on a boat last year....amazing...
Your engine should fall in this serial # range in link below. If so, click on 'Distributor and Ignition components' for the ignition wire part #.
https://www.mercruiserparts.com/454-...8-1988-1992-0b
F-2 Speedy 08-03-2019 02:09 PM
if the pugs are from 89 do them to.......:D
speicher lane 08-03-2019 02:12 PM
FWIW, I put Taylor Ign. wires on my BB cars but I cannot state if you will have issues on a stock Mercruiser/ marine electronics due to RFI interference. Some threads have indicated that problems started with aftermarket wire sets and resolved with a factory replacement set
(Hell yours are 20 years old so they do work!)
Prestigeworldwideee 08-03-2019 03:18 PM
yeah, I already replace the plugs. They were original too and looked terrible!
Prestigeworldwideee 08-03-2019 03:25 PM
https://rover.ebay.com/rover/0/0/0?m...2F163781515594
So these should work? Says it doesn’t work with 454 hi performance, that’s not referring to the mag, is it??
BUP 08-03-2019 03:33 PM
merc wires are made in mexico - bean counter made
Your ebay wires are the china ones good luck with those. Maybe a total of 3 USA dollars went into building those ebay wires, my guess is 2 bucks went into those build set of wires. And Im sure the emi and rfi is thru the roof.
For a small jist of info - Marine engines have wire harnesses all over the place thats why one of the reasons spark plug wires need to be of top quality including the boots. Also no air ever hits the engine compartments especially after shut down then heat soak takes place.
Tractionless 08-04-2019 11:18 AM
I ordered and built the plug end of Moroso 8.8mm's for a big block and hadn't had an issue with them in several years. Boat year round.
BUP 08-04-2019 12:11 PM
BINGO and ask me how I know.
