Gen VI MAG 496 injection shop
Need service or rebuild on my injectors with a Gen III Cool Fuel system. Who's the best and reliable shop in Ft Worth/Arlington area?
Originally Posted by PDQH2O
(Post 4722589)
If you don’t hit up BUP, just sell your boat now...mosetti is the best there is in Texas hands down!
Bup
I had BUP do my fuel injectors, and it couldnt have been a better experience. He went above and beyond, the boat runs as new.
Thanks for your input, guys. BUP it is.
Really appreciate your help. |
Hey BUP can you service Optimax fuel injectors?
Thanks guys for putting my name on this and do not forget I work on 496 s and almost all marine apps for the past 31 years. Not many can say that especially other fuel injector services that have never wrenched on one boat ever.
[QUOTE=Brandonb_05;4722705]Hey BUP can you service Optimax fuel injectors?[/QUOTE
1000 % many boat dealers send them in to me. NO BULL ----- 500 OPTIMAX air injectors and 500 OPTIMAX fuel injectors min per year. The air injectors have huge issues with internal carbon build up restrictions. That and air compressor failures are the leading issues that cause OPTIMAX powerhead failures. I post these issues all the time on my FB page. Others can vouch for that whom follow my page. |
https://cimg8.ibsrv.net/gimg/www.off...2350799a17.jpgLocal dealer Outboard injectors and OPTIMAX. This week all done and ready for pic up
https://cimg0.ibsrv.net/gimg/www.off...b9d287a94d.jpg
Before any cleanings |
Like I said carbon and carbon internally hugely restrict these air injectors
https://cimg8.ibsrv.net/gimg/www.off...d8c275345b.jpg
After cleaning and internal cleanings. You have to dissolve all the internal carbon so it can come out. |
Dissolved internal carbon and purged out of the air injectors. Its the only way to get it all out.
https://cimg0.ibsrv.net/gimg/www.off...3c1134ad06.jpg . |
Just wanted to report the 496 is gen VII that's all.
Thanks for the reply with pictures. I have 3 optimax engines I need to have the injectors serviced and checked. Do you need the fuel rails shipped to you with the injectors.
Look no further! BUP is your guy! I wish he lived near me. I recommend him all day long for the services that you need + more!
Originally Posted by Brandonb_05
(Post 4722720)
For the OPTIMAX just the fuel injectors and air injectors. You keep those rails and make sure they are clean and zero corrosion. They can be a son of gun to get out so watch out how you take them out without damage. It is best to have the service manual for these OPTIMAX per your engine serial number and hp range. Also it is best to have the special air and fuel pressure reading tool to test your running air pressures and fuel pressure before you pull all this out and after all goes back together and the air & fuel injectors are completely tested and cleaned on my end. There is specs that need to met for the air injectors side and then a different spec for the fuel side. Most of these apps are 10 psi difference but again that depends on the apps and year and which color air injectors you have. There is blue - black or grey for air injectors. Thanks |
Have to ask did any of these have an air compressor failure and or the cylinders that went down ? if so I would like to know which cylinders when down per which engine - and which engines had air compressor failures ? Mark the injectors per cylinders and engines THANKS again
| All times are GMT -5. The time now is 08:28 PM. |
