502 cam selection
502 single bravo drive 1.5 gear in 30 Velocity cm i ex looking for can ,more than stock mer c roller lifters don't want too much just good all around cam for a little more power any ideas???
Comp 11-775-8 Grind# CB XR271HR-12
Originally Posted by tripps
(Post 4739443)
looked up that cam out of curiosity . Is that cam choice real advice for pleasure use ? That's a lotta cam from specs I see |
Originally Posted by motor
(Post 4739855)
Originally Posted by ph1971
(Post 4739860)
Time tested profile. It will require good exhaust, spring upgrade,and I would do push rods and rockers. A good intake wouldn’t hurt either. 500@5200 or so. I don’t think that’s radical. Any less and the OP won’t notice much difference.
Camshafts COMP Cams Drag Race CB XR271HR-12 Mechanical Roller Camshaft Lift .775"/.748" Duration 324/332 RPM Range 5000-7800 |
Originally Posted by SB
(Post 4739863)
Think you listed wrong part#. The one you listed is a drag race solid roller
Comp Cams has changed their grind number system I believe. When I was looking for this cam for myself I also came up with the solid roller cam.
This is the cam PH1972 was referring to. This is a GEN 6 cam but they also make it in Mark IV also. https://www.jegs.com/i/COMP-Cams/249/01-775-8/10002/-1 Hardin/CP Performance also make the almost exact grind for the 454/502/540 |
https://cimg5.ibsrv.net/gimg/www.off...f44e08bc1.jpeg
I dug out the cam card. Some JEGGS customer’s going to be surprised when this is what shows up for his drag car. Ha |
comp cams copy of cranes 731.
| All times are GMT -5. The time now is 08:18 AM. |
