Just Died ?
Old 06-15-2020 | 05:59 AM
Default Just Died ?
OK, so i was out taking my sisters kids for a ride
1993 Powerquest 290 T -454 Carbureted 935 Hours
and Port engine just died and would not even turn over ?
So i looked at the Teather and it was there... pulled it off and back on.. NOTHING..
checked the oil and it is as perfect as that day i put it in.
moved Shiftier back and forth.... Nothing
Ok, Any idea of routes that i can take ?
powerqrudy is offline
Old 06-15-2020 | 06:20 AM
Check power to the dash, could be a bad cannon plug connection, or popped the main power breaker
Unlimited jd is offline
Old 06-15-2020 | 06:41 AM
Where is the main power breaker fuse ?
Old 06-15-2020 | 06:44 AM
On the engine harness, typically near the starter slave solenoid. Red button about 3/8” diameter
Old 06-15-2020 | 06:49 AM
i Should be able to see it ?
OK, i am on it...
Will report back.
Old 06-15-2020 | 06:52 AM
SB
In addition....$10 test light and $20 multimeter can be your best friend in times like this.
Can you see/access back if your ignition switches.
SB is offline
Old 06-15-2020 | 09:06 AM
Sounds like it lost power to ignition. Check if you have power at the coil with the ignition on, if not figure out why. Try jumping the neutral safety switch as well (yellow/red wire going to throttle/shifter).
LakeHuronPower is offline
Old 06-17-2020 | 07:47 PM
GUYS ... THANK YOU THANK YOU !
I GOT THE HATCH OPEN AND YEP IT WAS THE POWER SOURCE LOSE AS HELL ..
HOOKED IT UP AND AWAY WE GO.
THANKS FOR THE ASSISTANCE
Sorry i could not get the password to work on the cell phone or i would have been responding sooner.
Your Friend,
Steve Is The Oil Guy
