Distributor Won't Spin New Cam Gear >
Old 06-28-2020 | 07:40 PM
Originally Posted by motor
Try a non Chinese gear. if distributor was fine with old gear and no shims with new gear equal zero, throw that gear away
jmo
This gear came from cam motion. What makes you say it is Chinese?
Dutchboy is offline
Old 06-29-2020 | 12:19 AM
Did you compare it to the gear you removed?? There has to be a significant difference.
Griff is offline
Old 06-29-2020 | 12:27 AM
Yes I measured them. It's definitely taller from pin to top of gear. Would my old gear work if it was on a roller can or do I need this special ****.. I'm so tired of fn with this engine. It's all brand new and close.
Dutchboy is offline
Old 06-30-2020 | 11:51 PM
The gear you posted a pic of looks like a standard steel gear so the original gear should work. I would double check with Bob M
Griff is offline
Old 07-01-2020 | 12:32 AM
I spoke with Bob Monday morning, he advised me on how to fix it. Hopefully I sort it out.
Dutchboy is offline
Old 07-01-2020 | 04:46 AM
All i really meant by "chinese gear" is that sometimes you get a new part that is bad . A lower quality new part is more likely to have problems than a high end part . Do you know the brand of gear you were sent . Putting a gear on distributor is not rocket science.
motor is offline
Old 07-01-2020 | 02:30 PM
I get that its not rocket science, Its pretty easy lol. My factory gear was fine and this one fit up against the distributor. I wasn't sure if there was a reason. I'm under the understanding that its a Comp Gear, I have had a few people tell me that i need to either drill a new hole or just remove a thousandth of the top or until it spins freely. That is what I'm going to do
Dutchboy is offline
Old 07-20-2020 | 01:20 PM
UPDATE. Bob helped me sort it out. My Distributor is an odd-ball shaft size. Any gear that I put on it had the same problem. I shaved a hair off of it and it fit perfectly. Thanks RMbuilder for the help, and for persistently calling me to help me. What a stand up guy.
Dutchboy is offline
