Which valve spring compressor?
Which valve spring compressor are you guys using?
I tried this one, but it’s too small, too flimsy and the lever is too short. I need something stronger with a better leverage for double springs in my big block heads. https://cimg8.ibsrv.net/gimg/www.off...07988b928.jpeg Useless |
I have this one and has worked flawless for me. My current springs are 250/700lbs. Doesn't flex at all.
https://www.summitracing.com/parts/pro-66764 |
I made one out of a big c-clamp,takes off springs w/ 350lbs on the seat and 1100lbs when compressed.
I have a green one made by Goodsen. Wonderful tool
https://goodson.com/collections/valv...ing-compressor |
These things look tough, that’s what I need. Thanks guys, I know what to order now
Originally Posted by underpsi68
(Post 4757725)
Pneumatic valve spring compressors are nice if you have enough work to justify the cost. Assembly/disassembly time is much quicker and easier.
MTI Valve Spring Compressor |
(Post 4757670)
| All times are GMT -5. The time now is 04:47 PM. |
