Water Pressure Gauge quesiton
#41
Just did new impellers (and mechanical fuel pumps) and test ran the boat. I only ran her to about 2,500-3,000 rpm (50 mph) and saw solid 10-12 psi. I guess I am going to call this my baseline. I kinda expected higher pressures but water temp stayed stable ~140-150F (with 140 thermostats).
I am not sure why mine seems to run so low pressure?
The engine is in for an inspection/potential full rebuild at the moment, so hopefully It gets closer to normal readings after complete. So far, there seems to be a couple things that don't seem right with the new to me engine.
No Bravotits to be seen (corrosion of the water intake hole on the out drive) It's sitting on a stand in my garage and is a clean, fresh water OD.
The intake hose was replaced last year along with new gimble bearing and reverse cable.
New mercruiser impeller and housing installed.
New Faria Beade pressure gauge installed at thermostat housing using 1/8" nylon hose. (Don't know if length plays a role? I have about 25' of hose to reach the gauge in the dash)
Did find out the thermostat was missing from the engine.
The thermostat housing is not the one that came stock.
I am using the circulation pump
You can't see the water pressure fitting mounted on the port side of the thermostat housing. (the hose blocks the view) but you can see the black hose running along the valve cover for it.
#42
Is the preferred method of attaching the water pressure gauge through the 47440 thermostat housing or directly to the Hardin pump?
So, I think I found the correct port on my thermostat...agreed? What size adapter should I use?
I have some Gaffrig water pressure gauges that came with these connection adapters...which are too small to go directly into the thermostat.
I did notice that my Hardin water pumps seem to have a unused port already (that looks like it fits one of the connectors/adapters I have):
#43
Thank you for posting the results.
#44
I inspected and found gear oil diluted with fuel on one so I changed both fuel pumps...good call!
#45
Also, I have a lot of extra hose on a 33 foot boat so I am sure that I have 20'-25' of hose...as long as it is not flexing (teflon) or leaking the pressure should be accurate.
#48
FYI for anyone what circled in red port is for on your Hardin pump:
625-4221 INSTALLED (cpperformance.com)
CP Performance - Gen 5/6 Sea Pump Vent Equalizer
TomZ (12-07-2021)
#49
#50
I replaced one of my OE seawater pumps and pulley on my 32 Fever with the Hardin one and the vent kit. I already had the stainless housings. All very nice pieces BTW. I sold the boat before I could put more than 15 minutes on the new pump and vent kit to know if it helped anything. In my mind for the price of the kit (which is a few fittings and hose) if it gave me even just one more season before a failure it's well worth it!
