Stern drive slowly trims down >
Old 06-02-2021, 11:45 AM
Default Stern drive slowly trims down
I got a bravo that slowly comes down over a few days if left trimmed up in the barn. When under power it will also slowly trim down and I have to keep adjusting it.
Is it the seals in the trim rams or something in the trim pump? What's the right way to know for certain?
Thank you.
LakeHuronPower is offline
Old 06-02-2021, 03:32 PM
If you don't see oil leaking from the cylinders or an oil slick on the water, likely not the rams. The pumps have a base plate that fluid is controlled by a series of steel balls in an aluminum seat. Those tend to leak after a while causing them to lose pressure. I thought someone made an oversized ball kit, but that's been years since I looked.
CDShack is offline
Old 06-02-2021, 09:43 PM
Its most likely the valves in the trim pump. I had the same issue on a boat years ago. Replaced pump and all good.
Griff is offline
obnoxus (06-03-2021)
Old 06-03-2021, 06:56 AM
Is pump replacement the only option for repair? Or is the valve base plate available and replaceable? Or should I just replace the pump regardless since it is 28 years old...
flashgordon (06-03-2021)
Old 06-03-2021, 07:34 AM
I would just put in a new pump. I also used SEI Marine rams on mine, much cheaper than Merc, and 4 years later they still seem just fine to me.
https://www.sterndrive.cc/product/Fi...-98704A26.html
SabrToothSqrl is offline
Griff (06-04-2021)
Old 06-03-2021, 02:45 PM
It's by far the easiest! I've cracked open several pump bases without roaring success. Some work for a while, others never worked better, sometimes you drop a valve ball and throw the whole thing in the trash (long story) If you look around CL and Ebay, there are some that come up relatively inexpensive.
CDShack is offline
Old 06-03-2021, 04:08 PM
28 years it doesn't owe you anything
speicher lane is offline
LakeHuronPower (06-04-2021)
Old 06-04-2021, 07:29 AM
Thanks for the help.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information -
Copyright 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
