Getting it clean is great, but do any of you put anything back on to protect it after? Like waxes or something? Seems like some sort of a spray wax might be a good idea to make it easier to clean next time.
Ditto on the Ryobi battery powered pressure washer. Works fantastic on a dirty bilge. I use the Zep citrus decreased.
Padraig |
Be careful with pressure washers around any areas that have openings into the transom and stringer cores.
All good suggestions here. Believe it or not, I've found that a mix of Tide and Dawn with a little water in the bilge does a great job of keeping the bilge fairly clean. It leaves a clean and fresh scent too! ;) |
Just hook your pressure washer to the hot water heater
| All times are GMT -5. The time now is 07:44 PM. |
