-   -   Mercruiser 420 - Valve Adjustment (https://www.offshoreonly.com/forums/do-yourself-boating-budget/372063-mercruiser-420-valve-adjustment.html)
distantthunder 06-15-2021 01:54 PM
Does anyone have the appropriate valve lash/adjustment for the Crane valvetrain on the 420 mercs? I am picking up my cylinder heads from the machine shop tomorrow and was hoping someone has the information handy. I am reusing the stock rockers, lifters, pushrods, etc.
SB 06-15-2021 04:25 PM
Crane has always stated 3/4 to
one turn therefore half to three quarter is fine too
distantthunder 06-15-2021 05:19 PM
Thanks SB! I hope your summer is going well buddy.
Griff 06-15-2021 11:01 PM
Adjusting them before you install the intake manifold is easier to see/feel 0 lash. 3/4 turn is about perfect for Crane cams and will give about .040 of preload.
distantthunder 06-16-2021 07:53 AM
https://www.youtube.com/watch?v=8ROU7D-6meY
Thanks Griff, great to hear from you!
flashgordon 06-20-2021 08:54 AM
spin push rod ,,tighten rocker till cant spin push rod..then 1/2 ....3/4 turn...
Cory H 06-21-2021 09:06 AM
That would be too tight.
Loosen, then tighten while spinning pushrod between fingers. Stop when you feel the pushrod has begun to feel resistance as it touches lifter and turn to desired lash.
flashgordon 06-30-2021 08:37 AM
well,,best way run motor motors till hear rockers are loose,,,then tighten,,,but it makes a big mess running motor with out covers..,,but i stand corrected tighten till u feel drag on push rod,,then tighten..
F-2 Speedy 06-30-2021 08:41 AM
If their Morels almost a full turn down..........:D
