-   -   rocker arm adjustment (https://www.offshoreonly.com/forums/do-yourself-boating-budget/372222-rocker-arm-adjustment.html)
flashgordon 06-26-2021 03:28 PM
rocker arms adjustment,, so my isky card says 028 hot....
what would you adjust to cold?????
according to Power nations,,,they say iron block alum head...006 tighter????
your thougts???
thanks......
AmiableDave 06-26-2021 09:02 PM
My recommendation is it just them it's hot.
flashgordon 06-27-2021 09:49 AM
i could fire motors,,,then adjust,,,but it is a job getting my covers off,,and my thought is everything will cool off in ten minutes??
thanks..................
F-2 Speedy 06-27-2021 10:01 AM
Heat expands dont why you would set them .006 tighter ? unless Im missing your post
speicher lane 06-27-2021 10:11 AM
https://iskycams.com/contact-us.html
flashgordon 06-29-2021 09:08 AM
hey speedy,,,,
yea i set them at 22.......card says 28 hot..so went 066 tighter.
thanks ........
flashgordon 06-29-2021 09:15 AM
1 Attachment(s)
Originally Posted by speicher lane (Post 4795189)
thanks speicher....i sent them the question on adjustment.
thanks again..........................................
F-2 Speedy 06-29-2021 09:26 AM
back in my drag races days we set the intake at .022 and the exhaust to .024
Smitty275 06-29-2021 10:08 AM
The info for iron block and aluminum heads to set them cold and .006 tighter is a good starting point. It'll be pretty close. If your not gonna do them hot then this is your best approach.
Otherwise set them this way cold and get it hot, as in having run down the lake fully warmed up hot, and pop one cover at a time and fine tune them. Just warming up on a hose is not the same.
flashgordon 06-29-2021 10:49 AM
hey smithy,,,yea saw a clip on power nation,,,they said 006 tighter,,,
it just makes time to get covers out..like 10-15 mintes....so going with the 006 tighter...
thanks..............................
