Originally Posted by Tahoe540
(Post 4817967)
Engine parts can be hard to get right now. I buy a lot of parts through summit and most heads and other higher end parts are months out right now. I am building a 496 and have had to use other brands I normally don't use (like bearings) because of availability. Some good motors and short blocks show up on here and facebook marketplace sometimes if you are in a hurry. Summer comes fast when there is no motor in your boat LOL
So very true Tahoe on the parts scenario waited 12 weeks on MLS head gaskets, 10 weeks on Alum Rods ,6 months for AFR 385s ,and ordered pistons in October they promised beginning of December then Xmas then New Years now yesterday said there done being coated and in my hands in 7 Days ... Only one that was good was Comp Cam 5 days custom gring and delivered to my door :party-smiley-048: |
I recently had a 540 carb built from my 502 mag mpi. 712 tq @ 4700 and 711 hp at 5600. It’s in my donzi 22 Classic. I am really happy with it. I am currently ditching the emi exhaust and going to stainless marine.
Originally Posted by smokediver
(Post 4818048)
Originally Posted by articfriends
(Post 4818009)
Yep, I dynoed those 2 540s with 340 heads and they made tq similar to most 502s I build, had a terrible afr delta too, anywhere from 10s to high 14s, lack of signal!
Originally Posted by getrdunn
(Post 4818018)
What intake? Just curious. Can you pm me your ph number.
Tks john We also had Daytona boxes, I found the happiest timing curve vs power right away and it had very little effect on the afrs. Ultimately we took off the modded carbs and put ones on that flowed less, gave up 20 MORE hp and foot lbs of tq and afrs were "only" 3.5 points apart instead of 5. I threw fuel at it until the burn down cylinders were in mid 13's and lost even more power, but a boats got to be able to run at wot and not melt a piston on every outing! Smitty |
Originally Posted by ThisIsLivin
(Post 4818061)
Try a Jomar 1" phenolic tapered spacer, it improves signal and boosts midrange torque. Couldn't believe the difference it made for me. I also added a 1" open and it helped my top end. Both were noticeable improvements you could really feel in the boat.
At least they weren’t your builds. Damm the guy still had near or the same amount of money as builds making a lot more lower with better afr’s to boot. Nice to learn off someone’s mishap also.
(Post 4818070)
(Post 4818060)
Very nice! What cnc heads do you have. What a trip your Donzi must be. I remember back in the 80’s-90’s seeing those screaming at 70. You gotta be pushing low mid 90’s I’d think. 🤔
| All times are GMT -5. The time now is 06:30 AM. |
