575 sci valve spring?
What’s an equivalent or upgraded spring for a 575sci? Can’t seem to find the 24-13455T spring, and it’s also pretty pricy at $35 a piece.
stock cam and everything else. |
whats the spring rate
The old springs measure about 340lbs/in, springs have around 400 hours on them, not sure how worn they may be. I see plenty with a similar rate but these seem to be an odd size with an OD of like 1.45”, would rather not buy new retainers.
Hi, I was wondering if you found a replacement for the 24-13455T spring? I have found myself in the same predicament, and I am having a hard time finding new springs to replace this NLA part. Any advice would help, thank you!
For a stock cam, you can use aftermarket 575 SCI valve springs with similar seat pressure. Make sure the spring rate matches to avoid issues.
Originally Posted by SB
(Post 4945186)
Damn, if we lived closer i would just give you my 575 sci heads, just pulled them off for swap, they only have 112hrs.
| All times are GMT -5. The time now is 03:09 AM. |
