As you make adjustment to the mixture screws, give it a few seconds to find the new setting, then adjust the idle speed screw (throttle plate) to the recommended idle speed, usually around 700-800 RPM in gear. Repeat until motor is happy with vacuum and idle.
Originally Posted by Helmwurst
(Post 4832048)
Originally Posted by Zole
(Post 4832060)
great tip...but what shuld be my starting point..i know they cant be fully closed..screw in just enough so the engine can run or somthing difrent
Might be a problem with ignition system.
Originally Posted by TexomaPowerboater
(Post 4832086)
Originally Posted by Wally
(Post 4832088)
That is true....once had a problem where the engine idles great in neutral but always died when i put it into gear. Spent countless hours swapping parts. Turned out it was an advance spring inside the distributor that broke!
Is it an alpha or bravo drive? Alpha uses a shift interrupter that interrupts the ignition.
Originally Posted by liberator221
(Post 4832107)
| All times are GMT -5. The time now is 04:32 PM. |
