Carb in a box question
Old 06-07-2022 | 07:04 AM
Originally Posted by Zole
fuel pump makes 9 psi and my boost is going to be around 5 psi
I would keep a eye on your fuel pressure , sounds low , I like to have my pressure at 6lbs of pressure at idle and increase the fuel pressure 1lb per pound of boost pressure
green lightning is offline
Old 06-07-2022 | 07:07 AM
At 5lbs of boost you are only going to have 4lbs of fuel pressure
Old 06-07-2022 | 07:12 AM
SB
When using a mechanical pump, it can be boost referenced (increase fuel psi 1psi per 1psi boost) by connecting pump’s vent nipple to boost source ie: the box.
Now, if volume is enough from the pump, that’s another area to figure out/find out.
SB is offline
Old 06-07-2022 | 08:23 AM
i'll look into more before i start asking dum questions....engine is stil aut of the boat
Zole is offline
Old 06-07-2022 | 08:25 AM
great advice...now i have to learn the difference betwene lbs-psi..when i have some more numbers i'll get back to you..tnx
Zole is offline
Old 06-07-2022 | 09:11 AM
SB
pounds is same thing as psi in our lingo.
pounds is short for pounds per square inch.
SB is offline
Old 06-07-2022 | 09:49 AM
ok...your the man..
Zole is offline
Old 06-14-2022 | 12:01 PM
SB
Some peep’s run your system. Just ran into this post:
Can I run stock Y-pipes on a 500HP motor?
I’d check to see what carb # and how it is jetted/tuned/fuel pump used etc/etc. Always good to ask those who have done the same you are going to embark on.
SB is offline
Old 06-14-2022 | 12:58 PM
thank you SB realy means a lot...mostly im surfing throu som old posts on forum trying to learn as much as posible...thank you i'll take a look
Zole is offline
Old 06-14-2022 | 09:17 PM
Scarab28's Avatar
I have a complete spare box if you need one. Best carb for that app would be a holley 750. Fuel pump needs to be able to make 6 lbs at idle and 11 lbs when full throttle if making. 5 lbs boost..
Scarab28 is offline
