502 need help
Hey guys i opend up my faze chain on my 502 and this is what i got...
https://cimg6.ibsrv.net/gimg/www.off...97e4f8b79b.jpg So when it lines up like this the valve is hitting the piston.. https://cimg8.ibsrv.net/gimg/www.off...d2fddefbdd.jpg But when i put it like this then looks like everithing is ok...1 cil fiering 6 cil on overlap..On the first picture when i checked the cam the 6 cil was not on overlap but the 1 cil had closed valves...strange...Allso when i removed the chain gear from the cam i see that there are nubers writen on cam...it writes 32 cam with golden letters...What are your thinking about this? |
Can you post pic whole crank gear ?
And part # of timing chain set ? |
Originally Posted by SB
(Post 4855690)
And part # of timing chain set ? https://cimg1.ibsrv.net/gimg/www.off...1b1b9b59bd.jpg This is the best i have for now.I'm at my work place but as soon as i finish my job and get to garage ill take foto |
(Post 4855690)
And part # of timing chain set ? https://cimg1.ibsrv.net/gimg/www.off...1b1b9b59bd.jpg This is the best i have for now.I'm at my work place but as soon as i finish my job and get to garage ill take foto. The crank gear had 3 keyholls it had letters A...letter R...and two 0 marks |
Looks like its a Cloyes 3110 adjustable timing chain set
https://www.cloyes.com/hex-a-just-tr...110a-bb-chevy/ |
Might be a silly question but are you sure you're on the correct stroke in relation to crank/cam timing? Could be on compression for the crank and intake on the cam or vice versa??
Originally Posted by AllDodge
(Post 4855702)
The timing chain is installed correctly for 0 advance.
Originally Posted by BBYSTWY
(Post 4855703)
One thing that most people don't realize is that when you line up the dots on a timing chain, it is not cyl #1 at tdc, it is #6. That is why distributors get installed 180 deg off so often. Cylinder #1 tdc is when both dots are at the 12 o'clock position
| All times are GMT -5. The time now is 02:42 AM. |
