Black scorpion ecm modifications?
I have a 2007 tow sports 5.7 black scorpion. I bought it with the engine block cracked and put a 383 in it. Motor is in and running.
only mods were the cam (xm270hr) and the displacement. Do I need to tune it, or will the computer make it run well enough? If I need to tune what's the best way to do that? |
Don't see a motor serial number so I'll guess it has a 555 ECM. Merc tunes all motors fat and it may be ok but would need to get AFR readings to determine if a retune is needed. With out AFR readings or lots of plug analysis, then it needs to be retuned
The motor is from 07 so I'm pretty sure it's the 555.
I'm pretty sure it has 02 sensors and cats. I hadn't thought of checking afr. What are mechanics on doing that? Imagine that I want to be able to have the O2 sensors working properly so I guess I'd have to drill another hole? |
Accidental double post, sorry.
I'm looking up on BAM's site and last 350 MAG MPI had 555 but did not have CATs. CAT's came to Merc town in about 2010
If your motor does have CAT's then it has at least a PCM09 While reflashing a 555 is hard and not many can "actually" do it, no one can do a PCM09 that I've heard of To measure AFR it requires as you say O2 probes installed in the exhaust and see what's going on with AFR meters New ECM is $2300 |
Originally Posted by AllDodge
(Post 4856059)
While reflashing a 555 is hard and not many can "actually" do it, no one can do a PCM09 that I've heard of |
I would get current real time wide band readings and see what your existing AFRs are doing. If within limits run it. If not then get it tuned as mentioned above.
Originally Posted by AmiableDave
(Post 4856062)
Whipple can do both.....
(Post 4856076)
They say they can, but talk is cheap
NOW YOU'RE SAYING THEY LIE TO ME? Do you work there? I'm curious to know how you know their talk is cheap. |
(Post 4856078)
I called Whipple a couple of years ago and they told me they could reprogram PCM 0905. But I would have to run 91 octane and I didn't go through with it.
NOW YOU'RE SAYING THEY LIE TO ME? Do you work there? I'm curious to know how you know their talk is cheap. Another thing is Only whipple can do it, if it was do-able others would also You may be correct and they are the only ones that can do it, I just don't believe it |
| All times are GMT -5. The time now is 12:58 AM. |
