-   -   E.O.I.C valve setings questtion (https://www.offshoreonly.com/forums/do-yourself-boating-budget/378132-e-o-i-c-valve-setings-questtion.html)
Zole 01-21-2023 10:02 AM
Originally Posted by Griff (Post 4856670)
Did you replace the valves that were making contact with the pistons?? 99% chance the valves are bent.
I did the same thing once and installed the timing chain gears wrong. Intake valves hit the pistons lightly. All 8 intake valves were slightly bent.
Yes bended 8 intake valves...only a little so strait them out and reinstal.Tested with gasolin no leaking good seal
DrFeelgood 01-21-2023 12:17 PM
Straightened the bent valves? Is that even possible? I thought once a valve was bent, it was junk.
Zole 01-21-2023 12:26 PM
I took it to a guy that has a late mashine and he did it...wery good guy 60 years old l.Put the valve back put gasoline in intake and tested..No leak..
