-   -   LS swap (https://www.offshoreonly.com/forums/do-yourself-boating-budget/378336-ls-swap.html)
PODUNK RACING 02-07-2023 12:02 PM
LS swap
Decided to just start a new thread for all my LS questions instead of asking on old threads. First question.. what water pump is this? I can see it's been modified ports for water to exhaust.
Second question what flywheel is being used? 6L to bravo coupler.
https://cimg6.ibsrv.net/gimg/www.off...6f2d5430d3.jpg
DrFeelgood 02-07-2023 02:27 PM
Looks like an LS truck water pump that had the thermostat housing cut off and a hose end added on, plus those other fittings you mentioned.
Wildman_grafix 02-07-2023 04:19 PM
I think Hardin marine sells a water pump for the LS that will work in a marine ap.
Not sure if KEM or Marine power would sell the ones they use. GM builds them but those two put all the acc on.
Xcomunic8d 02-07-2023 07:58 PM
1 Attachment(s)
I used a standard water pump. I looped the heater core inlet outlet.
https://cimg0.ibsrv.net/gimg/www.off...a3e12bae2.jpeg
each exhaust design may be different. I went closed cooling using a RA0147048a
i have a whole write up on the closed cooling setup alone.
Use a standard LS flywheel (NOT a flexplate). If you can afford the aluminum one so much the better.
A bravo high hp coupler will bolt to the flywheel no issues.
Use a flywheel bellhousing with big hole in it.
this is what I used for bell housing
https://www.ebay.com/itm/36409477178...mis&media=COPY
you’ll probably need to drill a couple holes to match up LS block it’s fairly straight forward. Although a few will match up for you.
again you have my number if you need to call me.
crusader 6.0 LS setup
Attachment 577589
if you go closed cooling this is a huge help. Split coolant out of pump through exhaust risers to heat exchanger.
https://www.hardin-marine.com/vsearc...erm=543-300373
PODUNK RACING 02-07-2023 10:35 PM
Thanks for the replies. I do already have a bellhousing from my bbc. Was not planning on closed cooling. I like how that one water pump is setup like the picture i posted but i guess i could just run a sea pump and would like to possibly run just a water crossover from hardin marine this?...https://www.hardin-marine.com/p-1002...lications.aspx.
Xcomunic8d 02-08-2023 08:37 PM
Most of those open setups…so I’m told… have a raw water pump into the circulating pump. Sorry I don’t know where that pump came from but maybe you can find a shop to fab it up. However, I’m assuming they have a raw water pump somewhere. Asking a circulating pump to do a lift pumps job is rough…
id start here
leave your circulating water pump alone.
plumb my raw water pump into my inlet for circulating.., or do that crossover thingy.
then out the exit of my pump put on that tee splitter above.
split to my exhausts and your set.
add a raw water pump.
https://marineenginedepot.com/lsa-seawater-pump-bracket
https://marineenginedepot.com/60l-62...k-pump-adapter
https://marineenginedepot.com/bushing-for-seawater-pump
get a Johnson f6b-9 pump wherever you like. I got from Amazon I think.
I’m using an arp crank bolt. I also bought one of these 1157-0163 crank bolts. Either of those should work fine if I’d have bought the gm long bolt first I wouldn’t have bought the arp one. But whatever…
make sure you strain that water going through your block.
plavutka 05-07-2023 01:29 PM
Two questions which probably belong to this section:
Is it really necessary to replace the original exhaust valves with inconel ones?
I would also like to know if it is really necessary to install a plate in the sump pan that prevents the oil from "escapeing" from the intake pipe?
Tartilla 07-15-2023 12:30 PM
Inconel exhaust valves...always good insurance. If you are going to get new valves anyway, then not much of an extra cost.
Having the correct engine package and compression etc goes a long way, so you don't have to run retarded timing to keep the detonation down. Late ignition will heat up the ex valves.
Many guys don't run inconel, and have good results. RPM, Spring rates, and cam profile all play a part in valve life.
How are the heads setup...what is the guide to valve stem clearance...guide material etc.
The GM factory Inconel valves...apparently had welded on valve heads to the stem...making them a stress fail point.
No one wants to drop a valve head.
I got lucky when my 1970 LT1 crate Short Block with 292 heads overheated...and it just tuliped the intake valves a bit.
plavutka 07-15-2023 01:00 PM
It is original, new Crate engine LS3-480 with KEM-Kodiak alu exhausts, "marine" oil pan with "counterflow gates" (I do not know english words for this "hinges") and originall ECU 480 program.
PODUNK RACING 07-15-2023 10:54 PM
https://cimg0.ibsrv.net/gimg/www.off...614ed6a8f9.jpg
https://cimg1.ibsrv.net/gimg/www.off...b132ece5b6.jpg
This is what I ended up doing on the cooling setup on my engine. Engine is now in the boat.
Xcomunic8d 07-16-2023 03:03 AM
Looks great. Post some pics installed
PODUNK RACING 07-16-2023 10:09 PM
Thank you. I went way over on detail on several things that you will never see. Still have some touch up bilge paint to do and a couple of other small spots to touch up.
https://cimg2.ibsrv.net/gimg/www.off...7911a9e1e7.jpg
https://cimg3.ibsrv.net/gimg/www.off...20ebfe785c.jpg
Drewm3i 08-25-2023 02:24 AM
Looks nice! Is it raw water cooled?
PODUNK RACING 08-25-2023 05:37 AM
Thank you and yes
