502 running
https://youtu.be/im_9GUrNGrw
Posted this video yesterday on wrong forum...so i hope my profesors will se this |
Blower sounds good
Originally Posted by DrFeelgood
(Post 4859779)
Blower sounds good
Originally Posted by SB
(Post 4859783)
Good day to all of you...Can some of you tell me what should be Piston/wall clearence on my cheavy 502 with H127CP pistons(hipernautic)..Hope you all are warm and safe...thanks
Hypereutectic.
Stock 502 with forged pistons runs about .005 inch, if I recall, maybe up to .006 but not sure how that translates to using a Hypereutectic piston which is going to expand at a different rate than a forged piston. |
(Post 4860542)
Hypereutectic.
Originally Posted by Zole
(Post 4860547)
Thank you professor for your time...I can't find anywhere how muc pistons expande.Looked all of your posts with that topic but nothing..
I will ask, though, why you chose hypereutectic pistons for a forced induction application? Forged would be better. |
(Post 4860551)
I'd suggest you check with your piston manufacturer to see what they recommend for clearance. I don't know enough to guess for you.
I believe You have it backwards.
Low boost in an automotive application, you could probably do ok with hypereutectics. They don't tolerate detonation at all so boost must be kept low or the tune must be kept very conservative (or carb jetting very rich). The load in a marine application is more than automotive and the margin of safety will be less.
(Post 4860559)
(Post 4860560)
| All times are GMT -5. The time now is 12:08 AM. |
