-   -   What timing chain set for a Gen IV? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/378634-what-timing-chain-set-gen-iv.html)
phughes69 03-12-2023 03:43 PM
My engine builder wants me to get a 4 deg crank adjustable, torrington bearing on cam gear, dbl roller timing chain for my engines. The block is a MKIV, cam shaft is a flat nose hyd roller (couldnt get a stepped nose when the cam was ground), we are using cast aluminum timing covers and Crane roller cam buttons. He wants me to get 2 std lenght timing sets, and a -.005 set because one block had the mains line honed and hes not sure if a std chain will be too sloppy. (he did check the mains on the other engine and the alignment was fine). He is suggesting Rollmasters, but I cant find who sells them now. Any other brands that fit the bill
F-2 Speedy 03-12-2023 04:28 PM
https://www.google.com/search?q=roll...=firefox-b-1-d
these guys are here in KC good folks
https://www.performanceparts.com/rol...?sku=RLMCS2020
BillK 03-12-2023 06:08 PM
I have never had a problem using Cloyes timing sets. They are my preferred brand.
F-2 Speedy 03-12-2023 08:03 PM
I use cloyes
