Power steering combining valve trouble
I installed this combining valve (PT-13 on the drawing) which allows the power steering to operate from either engine or both at the same time. Today was the first time I was able to start an engine (port) and when I did, power steering fluid came out of the fill cap of the pump on the non running engine (starboard). I did not get a chance to see if the same thing happened if I started that (starboard) engine plus it made quite a mess and I didn't want to repeat. I have a feeling that I may have plumbed the valve incorrectly. I looked at this illustration and decided that the high pressure lines from the pumps should be in line with the filter (large silver canister) on the valve which in my installation would be the top 2 ports. The bottom ports I have as the return lines to the coolers. As you are looking at my install, the upper and lower on the right go to the port engine. FYI, the port pump is now empty and the starboard is very full. I did not turn the wheel so I don't know if the "power" steering was working or not. It could be there is a problem with one or both of the pumps? The pumps are original to the boat (1995) and sat empty for the last 2 years. Thanks for your help.
https://cimg5.ibsrv.net/gimg/www.off...3403230c6a.jpg https://cimg6.ibsrv.net/gimg/www.off...5d350b20e5.jpg https://cimg9.ibsrv.net/gimg/www.off...212906c454.jpg |
Is there a chance that I can't run the stock pumps and have to swap over to the single oil tank and new pumps? I hope this is not the case.
Hi pq, you need one reservoir that feeds both pumps and accepts return from both coolers. You probably have it plumbed correctly. I submitted a "Teague on tech" question on this subject which was answered by Bob. I bought his stainless reservoir too that makes it work. Mounts in same spot with a little mod. Mine is on stb motor port side to make plumbing more centrized. Plumbing to pumps and coolers need to be changed to work with new reservoir. Todd
https://cimg7.ibsrv.net/gimg/www.off...fc76e960bd.jpg https://cimg8.ibsrv.net/gimg/www.off...9275c4e09a.jpg |
Hi pq, a link to the article. It's in April 2020 speedboat mag.
https://teaguecustommarine.com/teagu...20/#more-17143 Todd 989-289-9240 |
Hi pq, sounding like you have the saginaw style. Here is link to imco cap discussed in article:
https://teaguecustommarine.com/bille...reservoir-tank Todd |
Hey Todd, Thanks for the link. I looked at the article and I BELIEVE it says I can keep my pumps? I just have to buy the sealed caps with NPT outlet and those go to a single remote tank? I think these are the caps but which tank? I found one that has 2 inlets. He has many tanks listed but not much info for each tank. Thanks again for your help. Rob
https://cimg6.ibsrv.net/gimg/www.off...856c2f4db3.jpg |
Yes you can keep the aaginaw style using the sealed caps. Since you don't need a large reservoir- have two on pumps- a small one will work.
https://cimg3.ibsrv.net/gimg/www.off...804598edb4.jpg https://cimg4.ibsrv.net/gimg/www.off...ee300bf27f.jpg this one has two fittings, one .25" one .5" I believe. Can be plumbed to work with the cap setup. I can check tomorrow. Todd |
Reservoir has 3/8" and 5/8" outlet.
https://cimg2.ibsrv.net/gimg/www.off...9429c8869a.jpg https://cimg8.ibsrv.net/gimg/www.off...9f34255ac2.jpg |
I have one of those caps if that's the route you are going...won't be needing it on my new setup.
https://cimg3.ibsrv.net/gimg/www.off...4aa2f34c49.png
This is the plumbing diagram that represents your setup best. Your valve might be plumbed backwards. This diagram showing supply(pump output) at bottom, and returns closest to helm output. Check it out and see what you think. Todd |
Originally Posted by Todd B.
(Post 4865534)
Reservoir sent. Todd
| All times are GMT -5. The time now is 11:48 AM. |
