Power steering pump modification?
Hi, how have you improved your stock merc pump for external hyd steering? Found an old thread were was recomended to enlarge the pressure side fittings orifice to 3/16", to get more volume and lighter steering at low rpm.
Didn't do anything to mine other than plumb it when I installed hydraulic steering. I have dual ram single drive and it steers like a dream. I think if it won't maintain pressure at idle you have a bad pump and you're just masking it with the larger orifice but I could be wrong...
Originally Posted by BBYSTWY
(Post 4866491)
Mine is the standard saginaw I think it is v belt pump...I am currently in the middle of swapping to a serpentine setup with the stock 500 efi PS pump and have seen hundreds of boats running hyd steering with that pump too.
(Post 4866497)
I bought a Jones racing pump recently, they make them with remote resevoir or built in.
Small and compact, havent used it yet. My old GM standard autoparts store pump worked just fine too, just bulky and it the way of my new idler https://cimg4.ibsrv.net/gimg/www.off...e2ef5049ae.jpg https://cimg4.ibsrv.net/gimg/www.off...9835597fe2.jpg https://cimg2.ibsrv.net/gimg/www.off...4ed60d3adb.jpg |
I drilled my pump orifice but cannot recall exactly what I did. The system works great but I do not have a before and after comparison.
| All times are GMT -5. The time now is 05:46 AM. |
