-   -   Crusader 454 (https://www.offshoreonly.com/forums/do-yourself-boating-budget/379586-crusader-454-a.html)
Fast Too Fast 06-13-2023 05:06 PM
Crusader 454
Hello,
I have a 454 crusader, block, heads and intake manifold only. I am going to tare it down and rebuild and convert to raw water with flush kit. My question is, can I use my bell housing from a gen4 454 mercruiser with b/w transmissions? essentially converting the engine from a inboard to I/O. Wondering if I can use different exhaust manifolds and other mercruiser components. Any help would be appreciated.
tommymonza 06-13-2023 05:22 PM
Originally Posted by Fast Too Fast (Post 4870550)
Hello,
Should bolt right up
F-2 Speedy 06-13-2023 05:41 PM
Is the starter going to be in the same place ? meaning are they both upper rear mount now with the flywheel ring gear on the back side
Fast Too Fast 06-14-2023 06:06 PM
Yes, the starter is up top with the flywheel gear.
