-   -   Testing the steering (https://www.offshoreonly.com/forums/do-yourself-boating-budget/379991-testing-steering.html)
Griff 07-23-2023 11:42 PM
Link does not work.
The only way to post videos on OSO is with a link.
I assume this is what you have going on https://www.jrmarine.com/videos.htm
Prestigeworldwideee 07-24-2023 06:15 AM
Originally Posted by Griff (Post 4874231)
Link does not work.
I’ve tried 1,000 times to post this YouTube link… try YouTubing “bravo 1 play” and it should be the first video that pops up.
youtube.com/shorts/I5Jk***PA3E?feature=share
Prestigeworldwideee 07-24-2023 07:38 AM
Link does not work.
Welp…. If I have to do that I’ll definitely have to have a marina do it…
Griff 07-24-2023 01:08 PM
http://youtube.com/shorts/I5Jk***PA3E
Griff 07-24-2023 01:14 PM
Originally Posted by Griff (Post 4874334)
I think it's a filter for foul language on OSO. Its filtering out F A G for the ***
Prestigeworldwideee 07-24-2023 01:56 PM
lol…. Jesus… you’re right
Prestigeworldwideee 07-26-2023 11:13 AM
If it is the gimbel ring which I assume it is… I got one quote so far:
Gimbal ring=$1547.00
swivel pin=$320.00
steering leaver=$300.00
plug kit=$30.00
Swivel pin seal=$28.00
Boots=$300.00
Trim sender (if needed)=$160.00
Labor=$1000.00-$ 1500.00
And they’re pulling the engine…
what else can i do to diagnose my problem?
Prestigeworldwideee 07-29-2023 10:15 AM
Originally Posted by liberator221 (Post 4874154)
Sounds like steering arm/tiller arm is loose on steering pin. The u-bolt that sticks through top just above outdrive needs checked periodically
Well, I’m gonna get a nut replacement for the u-bolt. Hopefully it’s just the nut that stripped. Do you think I could just get that at a hardware store? Or do I need to go to a marina? Personally I don’t think that tightening it will do anything, I pray it does because a nut is a lot cheaper than the gimbal ring.
Is the nut part number 11-862903?
Mbam 07-29-2023 02:41 PM
swivel pin=$320.00
plug kit=$30.00
Boots=$300.00
If it turns out you need to rebuild we can sell you a complete transom assembly for about the same as rebuilding yours.
https://www.mercruiserparts.com/merc...-bravo-transom
In any case try replacing the nut for sure!! The nut could be either 3/8-24 or 7/16-20 depending on how old your transom is.
Nut is #23 here
https://www.mercruiserparts.com/bam/...30969/11210/70
Hmmm there should be a different torque spec for the 3/8 nut but at this moment I cannot find it.
Prestigeworldwideee 07-29-2023 04:20 PM
Nut is #23 here
Yes, that’s the nut that I thought it was. The two stamps on my outdrive are 0C899934 and at the top of the transom 0D312836. I noticed a stamp that said “R150” or something similar, is that referring to the ratio?
