Merc 502 MPI spark plugs
Pulled spark plugs for an inspection. Lightly modded 502mpi putting out 460hp. Had NGKV Power 7 in it. Stock is AC Delco MR43T
what’s the recommendations? |
MR43T is equivalent to NGK BR6FS(stock on newer 502mpi's).
The NGK 7 heat range is one step cooler than the 6. The 7 is probably equivalent to and AC 42 heat range. What exact NGK plug are you using?? Are you having any issues with them fouling or ???? |
Spark plugs
Quote:
https://cimg6.ibsrv.net/gimg/www.off...31c484f0c.jpeg https://cimg7.ibsrv.net/gimg/www.off...3c1209764.jpeg |
If they have been fine for a couple hundred hours, then I'd replace with the same
Agree with Griff. You can go with the AC Delco plug as well. I prefer NGK, but my mechanic buddy installed Delco last time he worked on it.
It was just interesting to me that the engine builder decided to go with a colder plug than stock. The delcos are a bit hotter.
R5673-7 v-power 7 is what is in there
Careful sourcing NGK's there's alot of knock off's out there.
| All times are GMT -5. The time now is 12:40 PM. |
