502 Mag Oil Sender wire question.
Long story short, port motor oil has a press to fit sending wire on the oil psi sender. Stbd motor sending wire has an eyelet with a crush washer and a tiny nut. Needless to say the press to fit is 1000% times easier to get on and off.
Will this work? Thats all my Googlefu is coming up with after scorching my arm and torso trying to tighten that stupid nut. https://www.ebay.com/itm/272099180726 Shorter story: Low oil pressure traced to either a weak sender or bad wire. Either way, when I hooked up a mechanical gauge, I picked up 10psi across the board, so Ill take the win. (37-43psi from 1,000-3,000 RPM). |
Wow dude it says FORD right in the ad..... do not substitute auto parts for the correct marine parts SMH
Originally Posted by Sonic30ss
(Post 4876679)
Hint: There isn't! Anyhow Learman, what you linked should work given the ID is matched to your stud. I suppose every one of that style is consistent/standardized. Further here is part numbers and links to various "brands". You I'd guess have a Napa local if that's the way you want to go. Better value for the 50 cent part it is. Delco 12112171 Napa Echlin EC104 Dorman 85845 https://www.rockauto.com/en/moreinfo...sn=722&jsn=722 https://www.napaonline.com/en/p/ECHEC104 But oh no they say coolant not oil. OMG :hitfan: |
Thanks yall. Sonic is giving me a hard time because...well.....he is like that haha.
Im just happy to have dodged a financial bullet. |
Originally Posted by cheech
(Post 4876696)
Wow DUDE, like there's something specific about a wiring pigtail in a marine app versus automotive. :bong: SMH/WTF
Hint: There isn't! Anyhow Learman, what you linked should work given the ID is matched to your stud. I suppose every one of that style is consistent/standardized. Further here is part numbers and links to various "brands". You I'd guess have a Napa local if that's the way you want to go. Better value for the 50 cent part it is. Delco 12112171 Napa Echlin EC104 Dorman 85845 https://www.rockauto.com/en/moreinfo...sn=722&jsn=722 https://www.amazon.com/Universal-Tem.../dp/B06ZYM4HCW https://www.napaonline.com/en/p/ECHEC104 But oh no they say coolant not oil. OMG :hitfan: |
(Post 4876805)
Yeah it was a joke! I figured someone would overreact.....nothing more than one friend busting on another.
You never know, there are some on here that are "Marine" only part goons at times. |
Winter time you’ll get a lot more reactions. :)
(Post 4876825)
I sure missed the sarcasm. :lolhit:
(Post 4876834)
Paint it white or black, double the price and its magically a marine part.
Wait....wut? They come in blue? But seriously....that nut/washer combo is just asking to be dropped into Narnia.
| All times are GMT -5. The time now is 11:35 PM. |
