-   -   Bilge Blower vent tubing options (https://www.offshoreonly.com/forums/do-yourself-boating-budget/381173-bilge-blower-vent-tubing-options.html)
Tartilla 12-04-2023 12:56 AM
Looking to replace my bilge blower tubing.
I really don't like the wire wound dryer tube type options. Is there a more substantial type available that works well?
compedgemarine 12-04-2023 07:43 AM
brake cooling hose for race cars. I know they make it in 3" not sure about 4' but it comes in different colors and holds up better.
Tartilla 12-04-2023 10:58 AM
Perfect!
I'll check it out.
Tartilla 12-04-2023 11:04 AM
https://www.summitracing.com/parts/aaf-all42154
4" silicone impregnated woven fiberglass double wire wound.
It's about $10/ft.
Thr marine crap is about $1/ft. But not much is used, so the overall expense is low, and will last far longer.
Sydwayz 12-04-2023 11:16 AM
I was just going to suggest brake cooling hose as well. You can find it in orange and black, and sometimes few other colors.
f_inscreenname 12-04-2023 03:52 PM
Dryer hose is 4" in most cases. 3" has been used as bilge blower venting on from daily cruisers to mega yachts for a thousand years. Not sure why you would need a high temp break hose when all you are doing is moving ambient air temps?
Sydwayz 12-04-2023 04:40 PM
It's not about the high temp. It's about finding a quality product that won't fall apart in a couple years, and/or look like crap in no time.
AmiableDave 12-04-2023 09:08 PM
Lifetime warranty... http://www.westmarine.com/shields-ru...3_001_007.html
Helmwurst 12-05-2023 09:15 AM
Why not put in some metal dryer hose. That looks cool, won't rot and you can rinse it off if it gets dirty. Probably not rust proof though.
JaniH 12-05-2023 10:57 AM
How about PVC waste pipe. In Europe we have 3" and 4" system.
https://cimg7.ibsrv.net/gimg/www.off...a0a1204703.jpg
Sydwayz 12-05-2023 11:23 AM
Originally Posted by AmiableDave (Post 4886240)
https://pbs.twimg.com/media/CfGEOVqU...jpg&name=small
:D
Tartilla 12-05-2023 03:40 PM
I was thinking pvc sewer piping. It's relatively thin and lightweight. Printable. But ends up looking sketchy when the elbows get added.
The brake vent hose seems to be the best solution, and really what the marine industry deserves for such an important and forgotten part of the fire prevention system.
I think my current bilge fans are 4", but size is deceiving.
IGetWet 12-05-2023 05:56 PM
I’m not a fan of the standard blower hose either. Such an eye sore in an engine bay. It doesn’t improve the function, but I’ve seen a couple builders such as sunsation cover the hose with some sort of tubing to make it more aesthetically pleasing.
IGetWet 12-05-2023 05:59 PM
https://cimg8.ibsrv.net/gimg/www.off...80fb1957c.jpeg
See the blue covering in this one
Tartilla 12-06-2023 04:55 AM
Originally Posted by IGetWet (Post 4886302)
That is a nice setup.
Makes sense, use standard blower hose and use loom style exterior.
I don't have near the room as this, or minimalist clean look.
My engine bay is pretty busy with the Arnesons pushing the tranny/engine forward right to the firewall.
Gives great access to the transom...
I checked, and hose is 3". For some reason it felt larger.
I don't mind the look of the brake hose. Has a technical appearance to it.
Thanks for the great info.
IGetWet 12-06-2023 07:53 PM
This stuff looks better and a little more rigid
https://www.hardin-marine.com/p-1099...ilge-hose.aspx
